A.C. question
Old Jul 4, 2011 | 07:24 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
A.C. question
e99 is the truck. Just pressurized the system yesterday afternoon. Today, go to take off in this so called hot weather in WA and there is no cool air. Looked for leaks from the freon and did not see any. Checked the condensor, compressor, and all the other fittings for leaks. Didn't see any. Its got to be a slow leak somewhere. Is there a way to find the leak like the dye and black light set up or S.O.L.?
This is for PartsGuyEd.
Old Jul 4, 2011 | 10:19 PM
cory5517's Avatar
cory5517
They make a dye that doesn't require blacklights or special glasses. Should be able to pick it up at a local auto store.
Old Jul 5, 2011 | 12:18 AM
Fat Diesel's Avatar
Fat Diesel
Have you checked to see if the compressor clutch it engaging? The middle part should be spinning together with the plate closed to it.
Old Jul 5, 2011 | 09:44 AM
empiretc's Avatar
empiretc
like suggested, make sure the compressor is indeed engaging. it may just be an air gap issue.
if it is a leak, do yourself a favor and try any of these:
https://www.ford-trucks.com/forums/1...l#post10380025
was never a fan of stop leak in an a/c system, but these work. depending on the leak, it could take more than one can. it is still cheaper than freon & and a new dryer, and those are needed every time you tear into the system. chasing a freon leak is like looking for a needle in a haystack.
Old Jul 5, 2011 | 09:57 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Yes, clutch is engaging. Will try the leak stop.
