09 Lariat 4x4 gear ratio?
What was the standard gear ratio, and optional ratios available for the 09 F150 Lariat 4x4s?
I've tried searching but can't find what I want.
Reason I'm asking, is I found a 09 I want, but I was told it has 3.31 gears. Didn't think you could get those in a Lariat 4x4....
I want 3.73 and know that was a option, but 3.31?????
According to the spec sheet:
https://www.ford-trucks.com/specs/20...d-f-150-1.html
3.15:1 / 3.31:1 / 3.55:1 / 3.73:1
It appears that the 4.6L 3v motor and the 5.4L could be had with any of the 4 choices.
The 4.6L 2v looks to be just the 3.55 and 3.73
A Lariat SCrew 4wd would be 3.31, 3.55 or 3.73.
Also appears that the 3.15 are only available in 2wd
PM me the VIN and I can check it for you...but not until the morning when I'm at the rockpile.
I've got 3.55's in my 2010 Lariat. Had 3.73's in my '05. I was pretty stuck on 3.73's again until I read somewhere or was told that the 3.55's with the new 6-speed tranny actually have a lower 1st gear than the 3.73's with the 4-speed. Just made a run from S.E. GA to Dallas to pick up a '56 F-100 that my dad bought. Hauled it on a 20' tandem axle trailer of mine. The 3.55's and the 5.4l did great. No power shortage that I could tell.
