Engine Casting Number Help
Hey, Need help with block casting number, Trying to figure out if what I have is a 302 or 351. The block casting number is D80E-6015-E3A with date code = 8F27, also has near casting number on a tab a large 79, also has a sideways 27 in same area.
I pulled what I thought was a 302 motor from a 1970 F100 Ranger to use in my 76 Bronco, been having issue with getting it to fire up. Also if it is a 351, I used my original edelbrock alum intake manifold on this motor, I'm thinking if the block is indeed a 351, then my intake could be an issue as well as the firing order. Any help appreciated.
numbers dummy @ the members list in the blue horizontal line near top of this page (if no 1 comes along shortly). He's great!
Welcome to the forum, this site (altho not real active). We need more Bronks!
Lotta great and helpful folks. When U have 20 posts U can put up a pic of yer ride 4 us.
If U want boots-on-the-ground contact U can join yer local chapter (under the 'forums' button, also above). I meet local guys (& their assorted tag a longs) once a month for local adult entertainment and tech assistance.
Again, welcome, keep talkin...
Deck height(center of crank to top of deck) is a little more than an inch taller on the 351. Also distance between heads is about two inches(?) wider on a 351. I think you would have ran into problems putting it in as it's not a drop in replacement. Your 302 distributor will not fit in a 351, it's too small. Hope that helps a bit.
D8OE-6015-E3A = 1978 bare block casting number. But, there's no way to cross reference casting numbers to Ford part numbers, because they are foundry marks.
The engine could be either a 302 or 351W (both have 6 valve cover bolt holes per side). 351M/400, 460's use different block casting numbers than D8OE.
8F27 = Bare block cast June (F) 27, 1978 (8).
trozei
40
09-12-2020 09:22 PM
Amp.n.dewh
06-06-2016 06:14 PM
johnson.jeff.a
23
10-19-2015 11:04 AM
drew.law
01-23-2011 05:23 AM
