Leveling out the front end of my 93
I already put a 2" leveling kit in the front of my 93 F150 2wd and over the past year of installing it, its like the the springs just are kind of bowing out and it really isnt lifting the front of the truck much anymore. Is there any other way I can raise the front end? I just want it to set level with the rear but besides buying a leveling kit which i already did and doesnt really seem to be work to much anymore, i'm not sure what else to try. Ideas?
you could try those rubber things that stick in between the spring coils. they also have bolt in ones. i have the bolt in ones on my truck and they have worked pretty good for the last year. its a very cheap alternative to replacing the springs, but i cant say its the best thing to do.
heres an example
Amazon.com: Superior 18-1601 Rubber Coil Spring Booster, Small: Automotive
heres an example
What leveling coils did you get? Maybe they were some lesser quality ones. My friend has some Superlift ones and his truck still sits the same after several years and several thousand miles. Mine did too, until I put the stock springs back in.
Why would you lower the rear of the truck after lifting the front? I can see the point if you want it to be a street truck, but thats the only reason.
AaronNewman90
General Automotive Discussion
04-19-2022 04:58 PM
AaronNewman90
09-26-2016 12:18 PM
LPog
12-25-2015 07:19 AM
