2006 6.0 stumble
#31
check this
Had same problem with my 04 6.0 ltr. check it for a obstructed Exhaust/Catalytic converter at the down pipe before the cat. open the gap about an inch and run it. If you have a blocked Exhaust back pressure sensor you may have a Blocked Cat.. Takes 10 mins..
#32
ok..... results after driving it 3 different times today:
note: on the first run..... I guess I didn't have the clamp tightened down good enough on the tube below the passenger side battery. Was driving it and it blew off....... put it back on and tightened it back down good. hasn't blew again.
I still have a extremely small stumble and it isn't constant...comes & goes.
A collection of things I have replaced so you guys don't have read the whole thread.
- new EGR
- new EBP sensor / cleaned the tube and the hole where the tube attaches
- new ICP sensor
- removed and cleaned the turbo
- new fuel filters
- new oil filter
I thinks thats it
any thoughts
Dave
- new EGR
- new ICP sensor
- new fuel filters
- new oil filter
I thinks thats it
any thoughts
Dave
#33
After doing some reading:
I am "Assuming" that when everything is cold..... the vanes are in the closed position.
when motor is running the VGT accuates the vanes to allow the hot exhaust to exit.
I have also sent Garrett an email asking about the alignment thing. If / when they respond I will post what they tell me.
Dave
Dave
Dave the veins dont open to let exhaust out
the veins in the turbo move out as the truck accelerates this lets the turbo spin harder because it catches more exhaust gas to spin the compressor wheel therefore building higher boost on the intake side of things
hope that made sense
kinda starting to sound like a eletrical gremilin or injector thats starting to go
check the wire harness for chaff make shure everything is plugged in tight no bent pins
somewhere in the tech folder theres a great list of common wire chaff locations I will post it if I find it
https://www.ford-trucks.com/forums/9...condition.html
it might be in this thread try this click here^^^^^^^^^^^^^^^^^^^^^^^^^6
#34
#35
#36
and may also get a code
do you have any cel on???
#37
After replacing the turbo...I do not have a CEL on at this time ( Haven't drove it 60 + miles yet either)
Question:
2006 6.0 ..... I was looking in my "Owners Guide" to try and find the fuse # for the FICM .... I can't find it listed
what number location is for the FICM fuse ... could it be listed as a different name?
I thought it was #5 under the hood, but that shows IDM (Injector Driver Module)
Dave
#38
if it starts the ficm relay is ok and any fuses
but you will still want to check the ficm voltage
if you have a DVM you can check it
https://www.ford-trucks.com/forums/8...procedure.html
it needs to have 48volts at all times check yours and post results
also listen to the injector buzz make ure you are getting a good buzz from all injectors when you turn key on but do not start it
see if any inector buzz sound weak
#39
Yeah ... gonna check the FICM once I get my friend over here. I have actually checked the FICM with just the ignition turned to just before start.
reason I want to know where the fuse is for the FICM ... was gonna pull it and the fuel pump fuse / take the fuel filter cap off and see if I get any air bubbles in the fuel filter reservoir ..... this would let me know in some form that I have a bad injector o-ring.
#40
had all the ruff running issues when cold missing cylinders wouldnt shift right and so on but would be just fine after it warmed up
does the miss go away after the truck warms up???
If you get air bubbles at the fuel filter then you have a bad compression washer on the injector
does oil smell like diesel fuel???
#41
#42
Update:
CEL light is now on.... stopped by Autozone on the way to work for them to run the codes.
1st- (same old code) P0402
only thing I havent done for this code is check the EGR sensor
or
could a new EGR valve fail (stuck open)
__________________________________________________ ________________
New code:
P0231
- I think I might have bumped a harness or something when I was
removing / installing the turbo
Any thoughts ?
Going to pull the EGR valve out in the morning and make sure the valves are not stuck
Dave
or
New code:
P0231
Any thoughts ?
Dave
#43
#44
#45
ok.....
almost sure it is a fuel pressure issue. Reason being is that I ran the truck down to about 1/4 tank (maybe a little less) two times. Each time the stumble got worse.
Today I fill-up and runs almost fantastic. I do notice a extremely ........ very small hesitation every now and then.
so ......... could it be a fuel pressure issue?
Dave
Dave
