shake during acceleration
first,
check to make sure your vaccume advance is hooked up to the distributer
then I'd check each of the spark plugs (right after driving and recreating the miss) NGK Spark Plugs USA
I would not be surprised if you have one that is damp (unburnt fuel)
you could be running rich, (Carb is dumping too much fuel)
this could be causing your engine to load up and miss.
I'm sure more people will chime in soon (kinda slow on Saturday mornings)
good luck
good luck
also every once in a while it shoots a little white puff of smoke out the exhaust could it be a exhaust valve not seating correctly? and my choke wont go all the way in my dad said if the choke is stuck open that could cause the dry fouled spark plugs and the heavy shake when accelerating but i want a second opinion, because i wont be able to try until tomorrow
