Gas hose f-100 1977 replacement
im trying to replace a gas hose on my 1977 F-100 and i am new to automotive work so any help is helpfull but on the top of my gas tank i have 2 hoses the both are clamped on and move to the spout where you put gas in and they connect to each other at the end and i have to replace both of them due to cracking and leeking and i cant reach the clamps on the tank due to the bed so how do i replace this hose? do i remove the bed? or lower the tank? well i tryed to lower the tank and after i got the 2 straps off it would not budge. i guess i could just cut the hose off and cut the clamp i just cant reach there the screw is on the clamp.
if i posted this in the wrong section plz let me know so
I'm having trouble reading your post because of how little punctuation you have used. In order to get the best help, you need to slow down and make sure that others can read it.
Based on what I could make out of your question - are you talking about the filler and vent hose (larger set), or the sending unit and evaporative emissions hose (smaller set)? In either case you'll need to drop the tank down. If it hits the frame rails, try taking it down at an angle.
sorry about my punctuation i have bad English sorry....... and i got the hose off but i could not drop the tank i removed the bed but now im just trying to find the gas filler hose replacement how do i get them if they stop making them? i can use a straight hose that are sold in auto part stores! im am really confused on finding a replacement
You can get the filler hose here
Rear Filler Neck Hoses 1973-79 Truck
If you already went to the trouble of taking off the bed, this may be a good time to figure out why you can't lower the tank and replace straps if need so that way if a problem arises in the future, you'll be able to lower the tank and not have to take the bed off.
this isnt english class
i understood him fine
The hose I used was ribbed and seems to bend and flex nicely it was on the rear tank though id think it should work for front as well! Oh and make sure your gauge works before putting everything back together I get to take mine apart! Also does anybody know where to get the screen that goes on the pickup tube found one through ford they want $ 45!
fordtrucksforever
07-09-2016 07:36 AM
Old Brown Truck
10-31-2015 10:30 PM
