ZF6 clutch
ZF6 clutch
So i am planning on swapping out my auto for a <ACRONYM title="ZF 6 speed manual transmission">ZF6</ACRONYM>. I have found a manual set up for a good price but it comes with a stock NEW ford clutch. What are your thoughts on a stock clutch?? I am not planning on building insane horepower or a sled puller. I drive my truck daily and tow often. So I am building my truck to do just that. I have the mods in my sig. MAYBE one day I will upgrade to stage1's and a 38r MAYBE, but that is it. So would a stock NEW clutch be acceptable for my application?? If not what clutch would you guys recommend??
I run this clutch, shortly after installing my DP Tuner my clutch started slipping. So I went ahead and installed the South Bend 1944-6OK and I'm very pleased with it.
Riffraff Diesel: Solid Flywheel Conversion Kits
Good point. And hopefully I can sell the auto to help with the cost. And it is still cheaper than a rebuilt auto.
Here's a couple threads for you to read.
https://www.ford-trucks.com/forums/6...=Auto+ZF6+Swap
https://www.ford-trucks.com/forums/1...=Auto+ZF6+Swap
Thanks for the info!
Well I was searching craiglist today and found a complete zf6, tcase, pedals, shifter, slave and master cylinder for $800!!!!!! So Now I am saving up for that clutch.
Would you guys re use the master/slave cylinder??? Or should I spend the $170 for a new one??? Guy said the tranny has 126k on it.
Well every clutch I have ether had installed or put in my self I have had the master/slave cylinder replaced, saves from going back and replacing it at a later date.
Nice score! In this case I think it's ok to use a used mc/sc setup. Only because it is soo easy to swap out later if you have a problem.
Early indications show a nice improvement over stock with my Mazda RX-7 oil cooler too. I won't know for sure until I do a summer tow up some familiar grades.
Here's my whole story I'm sure you've read it.
https://www.ford-trucks.com/forums/1...-not-good.html
In my opinion save the $170 on the master/slave and put it towards a better solution in the pilot bearing/bushing area or a cooler. I think a 6-oh cooler would be nice on a ZF6...
wadeclinton
07-29-2014 12:56 PM
southtexasidi
145
01-31-2013 06:40 PM
