93' F-250 4x4, Sagging front end
Guest
Posts: n/a
I was told the sagging front end of the 4 wheel drive 3/4 pickup was a factory defect. The shocks bottom out and/or the bump stop hit the leafs when driving over something at low speed (not noticed while driving 20 mph). I was wondering if there were any options I had to replace the front end suspension to prevent the bottoming out and possibly level out the front end?
Fords are kinda notoriouse for drooping or sagging front ends.I also went to Superlift when I lifted my truck,but they do make agreat spring kit just to bring it up in the front but to maintain a higher but stock look.The truck looks so much better when its not sagging,(they just look like they are kinda "road hard and put up wet" when they are sagging. As Phillip pointed out the Diesel springs are the only way to go,especialy if you are running the diesel or big block.If you are looking into raising your truck for off road let me know and Ill give you a few do's and dont's.
Later,
Jeff / super@sierratel.com
91 F250 4x4
Later,
91 F250 4x4
on
That's normal behavior for all TTB Ford trucks, the wheels will straighten themselves out as soon as you pull forward again but if a little sag /-\ remains that indicates the springs are sacked and need to be replaced.
what springs are you talking about? the leaf springs? thats the only "springs" up there i guess right
