E brake installation
The cable exits the cab at the top of the floor plates that fill the hole around the steering column, you will see a bend in the top plate and the cable goes out sideways. The housing then clamps to the top of the trans crossmember on the passenger side. The cable then continues without its sheath to the rear crossmember where the rear brake cables come together.
The cable from the e-brake handle attaches into a swivel bracket at the rear crossmember under the bed. From there, separate cables (one per side) branch out to the rear wheels (from the swivel bracket). As you pull the e-brake handle, the swivel bracket turns sideways causing the other two cables to move and engage the e-brake at the wheels.
From what I remember, the main cable just hangs after it's attached to the cab with the little bracket (you can see it pictured a few feet from the front and then attached with the bracket on the cable rear (also seen in one of the pictures). It's under tension so it doesn't hang loose. The side cables are attached to one of the crossmembers on under the bed with the "L" shaped brackets pictured.
scottlathrop
08-16-2015 06:49 PM
SideWinder4.9l
01-06-2015 09:25 PM
mosigndude
06-24-2014 09:30 PM
TANDAMAN
06-08-2014 12:40 PM
