E brake installation
Old May 4, 2011 | 12:49 AM
iwanaflattie's Avatar
iwanaflattie
Hello.
Does any one here know jow to install the e brake??
My F1 came with the handle but no cable. I dont see the hole in the cab for the cable and I dont know where its held on the frame.
Thanks thanks for the info
Old May 4, 2011 | 01:19 PM
iwanaflattie
bbt any takers
Old May 4, 2011 | 10:04 PM
gearhead1952's Avatar
gearhead1952
The cable exits the cab at the top of the floor plates that fill the hole around the steering column, you will see a bend in the top plate and the cable goes out sideways. The housing then clamps to the top of the trans crossmember on the passenger side. The cable then continues without its sheath to the rear crossmember where the rear brake cables come together.
Old May 4, 2011 | 11:36 PM
51PanelMan's Avatar
51PanelMan
The cable from the e-brake handle attaches into a swivel bracket at the rear crossmember under the bed. From there, separate cables (one per side) branch out to the rear wheels (from the swivel bracket). As you pull the e-brake handle, the swivel bracket turns sideways causing the other two cables to move and engage the e-brake at the wheels.
Old May 5, 2011 | 12:30 AM
iwanaflattie
Thank you I only have one of the floor plates any suggestions of how to fabricate some or a close up picture?thanks
Old May 5, 2011 | 06:52 AM
hamz52's Avatar
hamz52
I can trace them for you. I think I have an extra set laying somewhere around here if you want to go that route. They wouldn't be too hard to fab up.
Old May 5, 2011 | 10:25 AM
iwanaflattie
that would be awesome Hamz,I might have to fabricate them since I am running a different steering column
Old May 17, 2011 | 12:48 AM
51PanelMan's Avatar
51PanelMan
A little late to the party, but better late than never.
Here's the cable assembly and bracket. The longer cable goes to the front (to the e-brake handle). The shorther cables go out to each wheel.
Old May 17, 2011 | 12:59 AM
iwanaflattie
Thank you Ilya I only have the main cable and the lever inside the cab.
However I have the 2 e brake cables from my ot brand rear end so I Can use that.
I just donk know where the cable goes under the cab.
And A HUGE thank you for taking the time to take pictures and post them fpr me.
Old May 17, 2011 | 01:14 AM
51PanelMan's Avatar
51PanelMan
From what I remember, the main cable just hangs after it's attached to the cab with the little bracket (you can see it pictured a few feet from the front and then attached with the bracket on the cable rear (also seen in one of the pictures). It's under tension so it doesn't hang loose. The side cables are attached to one of the crossmembers on under the bed with the "L" shaped brackets pictured.
Old May 17, 2011 | 02:14 AM
iwanaflattie
cool thanks
scottlathrop
Aug 16, 2015 06:49 PM
SideWinder4.9l
Jan 6, 2015 09:25 PM
mosigndude
Jun 24, 2014 09:30 PM
TANDAMAN
Jun 8, 2014 12:40 PM
FordLou
1997 - 2003 F150
Oct 23, 2013 10:08 PM
