09 F250 Supr Duty, 6.4L, Broken Rockers
#106
RE: Broken Rockers
Do not believe there is anything that will help with this issue. The customer that received the Reman engine was/is a religious maintenance person. The Truck had no mods and was used for highway towing. The issue to me looks like a design flaw with the rocker arm itself. It just is not heavy enough. Just my 2¢.
#107
This issue has been discussed on here a number of times. I don't think anyone has been able to pin point a cause. Seems too me that because they are at the end of the oil stream they probably get the least amount of oil. In stock form the 6.4L is subject to a good bit of oil dilution. That may not be the cause of rocker failure but it sure can't be doing much to prevent failure. A good thread would be to see how many 6.4s that were deleted early had failed rockers.
#108
So the DPF was deleted and it was tuned then, correct? Because trucks that regen make oil and likewise dilute the oil with fuel, which may in turn be a causative factor in these rocker arms failures. What was someone was telling me before that they're more than happy with 4% fuel dilution in their oil analysis report? Might want to change that line of thinking...
what is DPF?
