9" spring plates in a 49
Old 04-29-2011, 11:40 AM
thendrix's Avatar
thendrix
thendrix is offline
I know this should be fairly self explanatory but I guess I am having a dumb moment. i am talking about the plates that go on top of the springs to bolt the rearend in. I can't tell which way is up and which way is down. Can someone help with some pics? I don't have stock springs I have posies, if that makes a diffrence.
Old 05-04-2011, 10:20 PM
gearhead1952's Avatar
gearhead1952
gearhead1952 is offline
If you still have the stock spring plates you ought to see where the original ubolts sat. There should be very shallow grooves for the top of the ubolt to sit in. I'm wondering if you don't have the original plates as it should very obvious. I have posies rear springs also but they are the same width as the stock springs so the springs won't matter the top plate should be about the same width as the springs.
EDIT: I just reread your title and it says 9 inch rear. So your top plates may be wider than your springs I've taken a grinder and reduced their width to be the same as the springs. I used the F2 lower bracket when putting the nine inch in my truck and the ubolts are spaced out farther so you will want to use the 9 inch top plate and not your original stock plate.
Old 05-05-2011, 07:36 AM
mtflat's Avatar
mtflat
mtflat is offline
If the plates are flat it doesn't matter.
If they have grooves pressed into the outer edges the u-bolts sit in the grooves.
It they have raised ledges the u-bolts sit inboard the barrier to keep from slipping off.
Old 05-05-2011, 08:52 AM
thendrix's Avatar
thendrix
thendrix is offline
Cool thanks guys. I'll have a look when I get home. They are not the original plates so I guess I will look for grooves.
hotrod351
1966 - 1977 Early Broncos
11-18-2013 10:36 AM
armyaviation
10-19-2012 02:16 PM
TheDesertRat
03-20-2010 11:35 AM
Neal 97 250
04-27-2009 10:35 AM
seaves46
05-06-2008 06:46 PM
Quick Reply: 9" spring plates in a 49
