1978 - 1996 Big Bronco
Slight chugging at low RMP cruise
Old 04-26-2011, 10:45 AM
Anafiel's Avatar
Anafiel
Anafiel is offline
I just wanted to post this in case it proves useful.
I've been dealing with a slight "chugging" when cruising around town. When off throttle, 20-30mph, the truck exhibited a tendency to want to buck a bit. Nothing serious, just a little driveability issue that I felt "in the seat of my pants", if you know what I mean.
I've pulled codes, and read everything I could find on fine tuning this EFI system to no avail. I had previously replaced cap and rotor, wires, plugs, air filter, and oil, all part of a maintenance push when I first got the truck last February. Also had to replace the TPS, as it had failed.
The only things I hadn't done was fuel filter and O2 sensor. Yesterday I went ahead and finished the job with a new filter and sensor. While I was under the truck I had noticed a loose body bushing, and a harness or two that could of been better secured, so I went about tightening and securing along both frame rails.
I found my chugging issue. Both bolts that secure the transmission mount to the cross-member were at least two threads loose. I torqued them down, finished up my inspection, and took her for a spin.
Not only did the chugging issue disappear, but a "bump" when I engaged any forward or reverse gear went away.
So anyway, I just wanted to post this for information's sake.
Have a great day!!
KC8LTS
08-11-2017 03:44 PM
Sand Obsessed
12-19-2015 10:08 PM
alistairh
6.7L Power Stroke Diesel
04-03-2011 07:40 AM
Faster_Ford
17
11-11-2009 01:22 PM
Quick Reply: Slight chugging at low RMP cruise
