1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 F250 Super Duty brake issues.
Old 04-21-2011, 02:41 PM
Tarpon Chaser's Avatar
Tarpon Chaser
Tarpon Chaser is offline
Question 2011 F250 Super Duty brake issues.
I purchased a 2011 F250 in December of last year and have had brake binding issues from the start when edging up to the wall in the garage. I have had it to the Dealer 2 times with no results. the Truck now has 1,600 miles on it. It appears that the front calipers are not releasing when I ease up on the brake.
Does any one else have the same problem and is there a fix for the issue?
I have never had a truck with this kind of issue before.
Old 04-21-2011, 06:19 PM
senix's Avatar
senix
senix is offline
Received 1,440 Likes on 1,030 Posts
grease the slide pins for the calipers and see if that helps.
Old 04-21-2011, 09:57 PM
FireMe's Avatar
FireMe
FireMe is offline
There is a known issue with calipers hanging up on some vehicles. Right now, Ford is having the dealerships replace the caliper and bracket assemblies and shipping the old ones to engineering for investigation. We just had engineers out at our dealership last week to look at one. There is no permanent fix as of today.
Old 04-23-2011, 05:06 PM
Tarpon Chaser
Please FWD info on the break issue when you hear from Ford engineering.
Thank you
Old 06-06-2011, 09:37 PM
jpickett's Avatar
jpickett
jpickett is offline
Do you have any info on how to get Ford to replace the faulty parts? I also have a 250 that is presenting the same issues. Only difference is mine has actually gotten up to 714 deg on the left rotor and the right at 344. I've taken the truck into the dealer with the brakes smoking and they say that they cannot find the issue and can not fix the problem. My truck has off and on pulled to the right when you apply the brakes from mile one. It now has a squeak at low speed. Stops the second you apply the brakes.
Zejokee
09-23-2016 08:38 PM
SXIPro
10-29-2015 07:38 PM
Jenksie13
02-24-2015 10:47 AM
Ericwlod
6.7L Power Stroke Diesel
28
08-13-2014 10:45 PM
Demo-man
01-04-2012 03:44 PM
Quick Reply: 2011 F250 Super Duty brake issues.
