I have a 2011 F250 with 5k miles on it. Readly lift level kit and 35" Toyo MT's. Drove fine for about 4500k, now seems to pull to right when braking. Never noticed if it did it before, but seems to have come about in the last few days.
It drives straight when not braking and on a level road, just pulls when braking.
Any idea's. Figure it is close to its first oild change so I will let them deal with it, simply curious if this is a serious issue.
Tire pressure would be the first and easiest thing to check. After that I would be looking at the leftside brake caliper. It could be stuck, leaking or some other contaminant could be getting on the rotor causing the pads not to grip properly. After that, you are looking at something bent, broken or worn out. Good luck.
