Help! My speedometer quit working
Old 05-08-2011, 11:58 AM
code_red's Avatar
code_red
code_red is offline
I have a 1995 F150 , 302 , 5 speed trans with 119,000 miles on it. My speedometer quit working on me about a week ago and I avnt a clue where to look 1st for fixing this problem. Any help will be gratefully appreciated, thanks (Oh this is my son truck)
Old 05-08-2011, 12:00 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
First thing to do is check ALL of your fuses.. The speedometer is electronic.. Remember there is 2 fuse boxes..
Old 05-08-2011, 01:14 PM
subford's Avatar
subford
subford is offline
If fuse #8 & #18 are good then:
NOTE:
Only wiring harness end of connector is to be probed.
Connect Digital Volt-Ohmmeter to Pin 4 (speed in +) and Pin 5 (speed in -).
Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)?
OR,
If available, a frequency counter may be connected to Pin 4 (Speed in +) and Pin 5 (Speed in -).
Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)?
OR,
If neither a voltmeter nor frequency counter is available, vehicle speed control may be used as a good indicator. If it works normally, then the speedometer module is at least receiving a speed input signal and the wiring and sensor can be assumed to be good.
A wiring diagram:
b-series
1983 - 2012 Ranger & B-Series
06-27-2015 08:48 AM
Turmand
03-15-2015 10:54 AM
chuckj5
03-10-2015 04:17 AM
50trucking
09-23-2014 03:13 PM
Tom2003
08-11-2013 11:48 AM
Quick Reply: Help! My speedometer quit working
