checking cylinder bore
i'm going to try to re ring engine. Can i use a micometer and telescoping bore gauge ?? i was going to buy a cheap set.
also what the difference between using that or usings a dial . bore gauge?? or do i have to use both??
also i saw some dial bore guages with these 3 feelers on it?? what are those for??
Wen it comes to accuracy there is no substitute for a good bore gauge that reads on .0001". You could use a snap gauge and mics to get a idea where your at but there are so many places in a bore to check it would be a real pia to check like that so many times. There are actually 4 points on a bore gauge, 3 center it and one does the measuring.
what's a snap gauge???
i was looking at one like this
http://automotivetools4less.com/stor...s/CEN-6462.jpg
or is this one better?
http://www.lukesmachinery.com/Pictur...-Gauge-set.jpg
Is this what u mean by snap gauge? I was talking about using this and a mic.
http://images.harborfreight.com/cpi/...5699/05649.gif
piperig78
12-11-2013 11:14 PM
v8xploder
06-30-2008 11:25 PM
