I don't know if you had doors on the cab before but I would try and bolt them in. I only say this because after I did the repairs to mine and thought I was done and bolted the cab to the frame did I find out there's problems with massive door gaps!!!!! That kinda deflated me.
I made the same mistake, although its not too bad. The passenger side ended up being a little bit off. I'm going to have to live with it for a while.
Well there it is sitting on the frame, I will be taking a little break before bolting it on. The rear of the cab will be up a little higher when mounted.
