Tranmission mounted e-brake
I've been reading up on that parking brake setup- it has a few issues, but over-all it seems like a good unit. I found a few exploded diagrams of it as-well, but I still don't know if it will work with my 2wd NP435. It seems that attaching it to a 2wd ZF tranny requires replacing the main-shaft and a few other parts- but I can't find anything on the 435.
Anyone done this before?
Also, how would I get the thing off the junkyard donor truck? I heard some mention of it being a pain to get off, but can't find much info on it.
EDIT: How many splines are on that ZF tranny output? I believe I have a 28 spline NP435, I kinda doubt that a ZF from a F450 would have that few splines... This could be a deal breaker.
Sam
Sam
All the full size ford I have seen with married transfer cases has a round bolt patteren with one dowl pin.
Its been years ago but I did unbolt this same unit on my (89 F-450)truck. and it is just a matter of 6? bolts and one cable.
4WD transmission output shafts do not have ANY threads on them (this only applies to married tranfered cases)
divorced cases use 2WD trans units and another driveshaft.
You can see quite a bit from looking at pics found on ebay. look around you will see.
I got my lever! I got it from Wayne (aka 52merc) from one of his f-6 parts trucks. It bolted right up to my transmission, and it should work great! The only issue might be clearance between the dash, but I can't tell at the moment because the transmission is out of the truck.
As far as the actual e-brake mechanism, I think I'm sticking with the drums on the rear axle. I managed to find some cables for the setup that should work, I'll be installing them tomorrow.
Sam
Sam
Sam
Sam
Good luck on your install! Hopefully it all goes smooth for you.
I put the transmission in, so here's a picture of it and the lever:
I've still got to cut the front cable to length and modify it to work with the new lever, but I am very happy with it so far! I did have to make a bracket to move to back about 6-8 inches, otherwise it wouldn't clear the dash. Other then that, no issues!
Sam
Sam
PapaBearYuma
07-23-2017 01:31 PM
abe
13
05-30-2017 09:18 AM
DPDISXR4Ti
16
12-15-2016 07:57 PM
