My 00 excursion v10 tail pipe is pretty black. I replaced cop and plugs all motor craft and a new motor craft airfilter. Seems to run good. No codes. I am thinking of seafoaming the gas and intake on it
if you do have an issue with running rich, I personaly dont think you do but any things possible, the cause's of your problem would be the maf and oxygen sensors, theres also the possiblity of a jammed injector, you'll need a good tunner to check the short term fuel trims to see if theres a problem.
Reason: spelling
if it ain't broke, don't fix it - try everything BUT that stuff first.
MAYBE if you were going to add it to the fuel, and burn it, but that "stick the brake booster hose in it and run the engine" thing, well, that's just crazy.
