black pearl grill
Old 04-05-2011, 04:33 PM
65F1005.8's Avatar
65F1005.8
65F1005.8 is offline
black pearl grill
I finally got my grill installed, I painted it with black and silver pearl, what do you guys think? I think I might smoke the corner lights now.
https://picasaweb.google.com/lh/phot...eat=directlink
Old 04-05-2011, 08:03 PM
SilverE350's Avatar
SilverE350
SilverE350 is offline
Black always looks better than silver. I want to paint my chrome, 08' grill. Do you think the paint will stick?
Old 04-05-2011, 08:11 PM
65F1005.8's Avatar
65F1005.8
Yeah it will stick if you scuff well, I used perfect match universal Black Metallic, make sure you give it adequate cure time, thats why it took me months to get mine done, I rushed it and it bubbled and made it hazzy, then i painted it later and couldn't find screws for it, what a PITA. making a 3 hour project last forever.
Old 04-05-2011, 08:13 PM
SilverE350's Avatar
SilverE350
I was told to use a scouring pad, is that correct?
Old 04-05-2011, 09:04 PM
65F1005.8's Avatar
65F1005.8
do you mean a scotch bright pad? I would use some 1000 grit sand paper, and wet sand it, you will remove any debris and tar and smooth and casting marks or imperfections and provide a smooth textured finish for the paint or primer to stick to. if it is plastic i would just shoot the paint.
Old 04-05-2011, 09:24 PM
SilverE350's Avatar
SilverE350
Yes, it's just chromed plastic.
Old 04-06-2011, 05:41 AM
JWA's Avatar
JWA
JWA is online now
Received 1,394 Likes on 1,103 Posts
Definitely use a Scotch-Brite pad to scuff any surface you'll eventually paint. This roughs up the surface which breaks that ultra smooth finish which does not allow paint to adhere properly. In no time at all the paint would begin flaking off.
There are many materials useful for such a project but instead of the aerosol spray cans visit a professional paint/body supplier and have them mix your color of choice. They can then put it into a spray can that's similar to off-the-shelf stuff but much much higher quality. Also check into a good quality plastic primer which goes a long way in giving a nice apperance and long life.
Here's a photo of my '00 E250 with painted grill and headlight covers. Its quite raggedly looking now but will get all new parts and paint this summer----a nice look I think, certainly different than most we see coming and going. Keep in mind for pretty cheap prices you can find a gently used grill and refinish it off the van allowing it to cure over time.
Old 04-06-2011, 10:21 AM
65F1005.8's Avatar
65F1005.8
orielly auto parts will mix dupont paint and put it in an aerosol for 24.95, some people prefer scotch-brite pads but I have always felt they don't hit every spot like sand paper does, one time with a piece of paper or several strokes with the scotch-brite to get the same dull even finish. thats just my opinion.
Old 08-16-2012, 04:58 PM
SantaAna12's Avatar
SantaAna12
SantaAna12 is offline
If your still around: How is the paint holding up on that grill? And did you use that same paint on the rims? Is there clear over....or just the paint?
Old 08-16-2012, 05:11 PM
avenge's Avatar
avenge
avenge is offline
Reviving an old thread but the black metallic looks exactly like what I used to paint my bumpers, headlight bezels and door handles. It holds up fairly well, the only thing I just repainted was my front bumper it was pitted no clearcoat.
My grill is a chrome billet grill.
jwhopson
06-03-2012 12:23 AM
GreaseMonky
35
06-29-2011 06:27 PM
Donald Garrard
02-25-2011 07:38 AM
jle70
23
01-22-2011 12:03 AM
Quick Reply: black pearl grill
