6.2L V8 Discuss the 6.2L V8
Leveling Kit
Old 02-24-2014, 10:19 PM
Rusty74's Avatar
Rusty74
Rusty74 is offline
Leveling Kit
I'm thinking of a 2" leveling kit for my 2012 SD, I did my last 08 PSD and needed a adjustable track bar to center the axle. Will I need to do the same on this truck? I currently installed F350 blocks and shocks on the rear and will put Air Lift bags on if I do the level.
Thanks in advance!
Old 02-25-2014, 03:20 PM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
ya to center the axle you will need either a adjustable track bar or you will need a drop track bar bracket. also to keep everything else in line you will need the trailing arm drop brackets . i just bought the readylift sst level kit. has everything to keep
the front end in line . i got mine with the 5" rear blocks. shock extensions are only required if you go off road or longer shocks. i do believe they sell the kits with out the rear blocks . there called the f350 kit coz they have 4" blocks already, right now they will knock 10% off advertised price if you ask .so you should be able to get a kit for less than 400$
Old 02-25-2014, 05:58 PM
Rusty74's Avatar
Rusty74
Rusty74 is offline
That's what I thought, I didn't think the would be any difference from the 08 front end. If I remember the track bar was around 450.00 from ICON and for that price I may go with a 3" suspension lift, but I'll research the SST.
Old 02-25-2014, 06:47 PM
Amelio's Avatar
Amelio
Amelio is offline
Is the SST kit a 2" leveling kit?
Post up some pics....... I also have a 2012 CC 4x4 and want a little bit of lift.
I always get confused by how they call it a "leveling" kit. I have measured and my truck sits damn near level stock.
So would the kit you bought also be what I would use?
Thanks!
Old 02-25-2014, 07:02 PM
Hotrod70d's Avatar
Hotrod70d
Its a 2.5 level kit with 4" block its the tow package with the 5" block the 5 wont be quite level slight rake. They make a 3.5 for the diesel if you wanna modify your exhaust slightly for the drive shaft. There web sight has all the diff kits
Old 02-25-2014, 07:06 PM
Amelio's Avatar
Amelio
Amelio is offline
Yeah I am not at all interested in modifying my drive shaft.
I want to just bolt on a kit on my drive way without any other mods.
Old 02-28-2014, 01:36 PM
Rusty74's Avatar
Rusty74
Rusty74 is offline
I have found that ICON makes a Stage 4 2.5" kit and has all of the necessary parts to keep everything correct but it will cost around 3,000 just in parts, you get what you pay for!
Old 02-28-2014, 04:19 PM
Hotrod70d's Avatar
Hotrod70d
ya but i cant see it being worth that much more for only 2.5 inches maybe 8 to 10 inches . im not off roading like 80 percent of the people just lookin for a little more clearance .my offroading is bringing in hay from the field and its hot and dry.
Old 02-28-2014, 04:54 PM
Rusty74's Avatar
Rusty74
Rusty74 is offline
I understand I think the shocks they offer in the kit are what makes it expensive , I would only want to do this so I can gain more clearance when I have tire chains on for hunting but that is only one week out of the year plus it looks good.
Old 05-13-2021, 08:02 PM
ATLScott's Avatar
ATLScott
ATLScott is offline
I went with the 2.5" on my 2021, and I'm perfectly level. You'll want the drop bracket to keep your axle centered, otherwise it will be off a half inch or so on one side (or so I was told).
shark1979
6.7L Power Stroke Diesel
23
12-08-2013 09:46 PM
madcatter33
03-13-2013 12:04 AM
Tjhunter-jeepman
02-02-2013 08:12 PM
cory5517
01-09-2012 07:36 PM
ffadragon
1999 to 2016 Super Duty
13
02-16-2007 10:29 AM
Quick Reply: Leveling Kit
