6.2L V8 Discuss the 6.2L V8
Leveling Kit
Old Feb 24, 2014 | 10:19 PM
Rusty74's Avatar
Rusty74
Leveling Kit
I'm thinking of a 2" leveling kit for my 2012 SD, I did my last 08 PSD and needed a adjustable track bar to center the axle. Will I need to do the same on this truck? I currently installed F350 blocks and shocks on the rear and will put Air Lift bags on if I do the level.
Thanks in advance!
Old Feb 25, 2014 | 03:20 PM
Hotrod70d's Avatar
Hotrod70d
ya to center the axle you will need either a adjustable track bar or you will need a drop track bar bracket. also to keep everything else in line you will need the trailing arm drop brackets . i just bought the readylift sst level kit. has everything to keep
the front end in line . i got mine with the 5" rear blocks. shock extensions are only required if you go off road or longer shocks. i do believe they sell the kits with out the rear blocks . there called the f350 kit coz they have 4" blocks already, right now they will knock 10% off advertised price if you ask .so you should be able to get a kit for less than 400$
Old Feb 25, 2014 | 05:58 PM
Rusty74's Avatar
Rusty74
That's what I thought, I didn't think the would be any difference from the 08 front end. If I remember the track bar was around 450.00 from ICON and for that price I may go with a 3" suspension lift, but I'll research the SST.
Old Feb 25, 2014 | 06:47 PM
Amelio's Avatar
Amelio
Is the SST kit a 2" leveling kit?
Post up some pics....... I also have a 2012 CC 4x4 and want a little bit of lift.
I always get confused by how they call it a "leveling" kit. I have measured and my truck sits damn near level stock.
So would the kit you bought also be what I would use?
Thanks!
Old Feb 25, 2014 | 07:02 PM
Hotrod70d's Avatar
Hotrod70d
Its a 2.5 level kit with 4" block its the tow package with the 5" block the 5 wont be quite level slight rake. They make a 3.5 for the diesel if you wanna modify your exhaust slightly for the drive shaft. There web sight has all the diff kits
Old Feb 25, 2014 | 07:06 PM
Amelio's Avatar
Amelio
Yeah I am not at all interested in modifying my drive shaft.
I want to just bolt on a kit on my drive way without any other mods.
Old Feb 28, 2014 | 01:36 PM
Rusty74's Avatar
Rusty74
I have found that ICON makes a Stage 4 2.5" kit and has all of the necessary parts to keep everything correct but it will cost around 3,000 just in parts, you get what you pay for!
Old Feb 28, 2014 | 04:19 PM
Hotrod70d's Avatar
Hotrod70d
ya but i cant see it being worth that much more for only 2.5 inches maybe 8 to 10 inches . im not off roading like 80 percent of the people just lookin for a little more clearance .my offroading is bringing in hay from the field and its hot and dry.
Old Feb 28, 2014 | 04:54 PM
Rusty74's Avatar
Rusty74
I understand I think the shocks they offer in the kit are what makes it expensive , I would only want to do this so I can gain more clearance when I have tire chains on for hunting but that is only one week out of the year plus it looks good.
Old May 13, 2021 | 08:02 PM
ATLScott's Avatar
ATLScott
I went with the 2.5" on my 2021, and I'm perfectly level. You'll want the drop bracket to keep your axle centered, otherwise it will be off a half inch or so on one side (or so I was told).
shark1979
6.7L Power Stroke Diesel
23
Dec 8, 2013 09:46 PM
madcatter33
Mar 13, 2013 12:04 AM
Tjhunter-jeepman
Feb 2, 2013 08:12 PM
cory5517
Jan 9, 2012 07:36 PM
ffadragon
Feb 16, 2007 10:29 AM
