Starter Interchange Compatibility??
Old 04-02-2011, 06:03 PM
money giver's Avatar
money giver
money giver is offline
I have a 97 Ranger 4 Cylinder and want to know what other vehicles or Ranger years my starter is compatible with. All help is appreciated!
Old 04-05-2011, 10:46 AM
money giver
I'm hoping somebody here can post some info here to help me. Thanks
Old 04-05-2011, 10:17 PM
michigan66's Avatar
michigan66
michigan66 is offline
Folks at a salvage yard or at an auto parts retailer should be able to tell you. I checked the listings in my LMC catalog and the newest Ranger they list is for the 91 - 92 model years.
Old 04-05-2011, 10:47 PM
money giver
Does anyone know if a starter from a manual transmission ranger will be compatible with an automatic transmission or if off a six cylinder will fit a four cylinder? thanks
Old 04-05-2011, 11:08 PM
michigan66's Avatar
michigan66
It looks like the starter is the same for MT and AT set-ups but each displacement engine has a different starter.
Another option, depending on the condition of your present starter is to get a repair kit. The kit is much less expensive than a remanufactured or new starter.
By the way, have you checked places like J C WQhitney or Rock Auto?
Old 04-05-2011, 11:28 PM
money giver
So the starter would need to be from a 2.3L engine in order to fit mine. No starters from any 6 cylinders will ever fit a 4 cylinder engine. Is this correct? Thanks for all your help.
Old 04-06-2011, 04:26 AM
michigan66's Avatar
michigan66
That is correct. I just checked the Rock Auto website - they have a choice of starters available.
Old 04-06-2011, 06:03 PM
money giver
I found a starter from a 2003 2.5L engine. Do you know if this will fit a 1997 2.3L Engine?
autox65
08-31-2016 10:27 PM
GRanger86
08-23-2016 04:38 PM
Sorianofan15
11-14-2014 08:22 PM
danger_ranger79
Electrical Systems/Wiring
05-29-2012 08:10 PM
evg1973
08-13-2010 10:55 AM
Quick Reply: Starter Interchange Compatibility??
