98' ranger leaky back window
before you go nuts on the window make sure it is the window with a 2 part test. Get some of that nonmarking painters tape and clean the area around the top of the window. Tape it up and hose the window and the rear brake light. Then take the window tape off and tape up the brake light and hose again. Recently discovered that my leaking rear window was actually the brake light seal.
Again, before taking that back window out, confirm where the leak is coming from! Mine was dripping on both sided only in heavy rain at the corners of the rubber window gasket. Its possible, though not very likely that it can be 1/4 windows if its an extended cab. The third brake light seems to be a constant source of leaks on these and the f150s from what I can tell. Good luck and let us know what you come up with!
edit:
when I got my truck it had a broken out rear window. I replaced it with a solid window and used rubber silicone. Leaked and leaked. Figured I did a bad job. Got proper rope gasket, basically ford replacement, pulled window, resealed it. Guess what? Still leaking. Did the tape test and have realized it was the brake light. Used strip caulk as a temp test for a few weeks. Now need to come up with a perm fix. Spent a lot of time and headache! Just want to make sure you dont waste your time with that window if thats not it!
edit:
blazinjames
03-03-2017 10:46 PM
