Serpentine Belt
Serpentine Belt
How difficult is it to change the serpentine belt on a 2002 Ford Excurison with the V-10. I have the tool to release the tension. Also I got a fuel filter at Fram fuel filter and the ends are not the same as the one that is currently on the Excursion. I have 160,000 miles on it, already changed plugs, new coil packs, had tranny serviced anything else anyone suggests to change or check out?
Thanks!
Thanks!
Fuel Filter
I went to Orielly's and got the fuel filter and the supposed tool to remove the clips. I still can't figure this out. I am feeling dumb. The end towards the back of the Excursion is a black pipe with a blue clip it looks like of some kind. I can't figure it out, the tool from Orielly's does not look like it works on it. The other end towards the motor has a metal clip which I unclipped. The new fuel filter came with two white clips like the Fram one but it does not look the same.
Headviking
02-16-2011 07:49 PM
Camp Upshur
06-25-2009 07:15 PM
