EGR plug.
EGR plug.
I want to either
1). Install EGR port plug and keep my current EGR valve plugged into the wiring harness to maintain correct computer operation;
or
2). Buy an additional EGR valve to plug into the harness while leaving the current EGR valve in place and disconnected from harness; with this option, will exhaust pressure push the valve open?
I have found that I can find either the port plug or an additional EGR valve for the same money. Sole reason for this is to keep soot out of engine. Don't care about mileage, etc.
Which would be best. Will this cause any other problem to arise with the cooler, etc. Also, will this cause me to have problems with too high exhast temps.
Any input would help.
or
sounds like a good and cheap egr deleate
it seams like a full egr deleate runs about 280.00 to 350.00 for the kit off the net
maybe I should consider this
on another thread you probably read the same one he got it off ebay and the welds leaked
I would think that you could probably pressure test with an air compress before you install the welded cooler
f100beatertruck
07-29-2013 07:41 PM
Keith460
01-15-2001 01:35 PM
