Confused about Ratio change
I'm rebuilding my f150 and am planning on a 4inch lift, and going to 33's. It has a 4.10 in it, do I need to go to 4.56? What I have researched says I need to go to 4.56. The tricky part is, I'm also putting in a zf 5 speed in with the wide gear ratio. 5.76-.76 What am I looking at then?
Thanks in advance.
Thanks in advance.
on
What engine will power this rig?
I'm tempted to say 4.10's are enough with the ZF, it doesn't have a very deep overdrive compared to some of the automatics so you'll want to be conservative to keep highway rpms under control. BUT.... if this is a 5.0 truck then it'll need all the help it can get and a little more rpm is your friend.
What he's saying is that given all things the same (tires, diff ratio, transfercase) you'll be turning more engine RPMs at the same highway speed with the ZF as opposed to say an auto overdrive..
For example top gear ratio in the ZF 5 speed is some thing like .76/1 while an E4OD is .71/1 ratio... IMO the difference is so minimal its not even a factor, especially when you consider the ZF manual has 5 incremental ratio's...way better...
If I were you I'd just run it like it is with the 4.10s with 33s..That actually sounds about perfect to my ears... If you don't like it-----then spend the money and change the gearing...BTW, You want to highway tow in 4th gear (1/1) anyway right.. Should be right in the sweet spot..
Trust me, you are not going to haul much stone with that half-ton no matter what gears you have in it. You can put bigger springs on it, then the brakes become an issue.
I purchased an old 1 ton dump truck when I built my house. It still wasn't big enough to cost effectively haul much stone or dirt or whatever. With the price of fuel, I found it cheaper to have a local hauler bring any materials I need.
wyleeone
06-04-2004 06:36 AM
rahal
08-20-2001 08:12 AM
