ok need some help again
Old 03-26-2011, 08:03 PM
seanjackmc's Avatar
seanjackmc
seanjackmc is offline
So I recently traded in both truck and 5er. New truck is a 2011 F350 CC FX4 SRW. New trailer is a Montana 3750FL. Truck pulls this trailer great. Under all my weights by a good amount. Did a cat scale check to be sure. Only problem is my truck is so high that my trialer looks as if its driving up hill. I actually dragged the butt end pulling out of the truck stop with cat scale. There seems to be some debate on how to raise the trailer. Any ideas. I think 4 inches would make a huge difference. Other then bottoming out I want the weight to be evenly distributed over the trailers tires.
Thanks for the help in advance.
STM
Old 03-26-2011, 08:15 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
SUPERDUTY_08 is offline
i know what you mean, I lowered the hitch position a couple years ago to level the king pin side, but last year found that I was getting to close to the bed when backing into a couple campsites. I had to slide the hitch back to keep it from hitting. I raised it back up this year in prep for the new camper...we will see how that sits.
Old 03-26-2011, 10:01 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
Have you considered flipping the axles?
Click.
Old 03-27-2011, 05:00 AM
mlb4966's Avatar
mlb4966
mlb4966 is offline
Ditto on the axle flip.
Old 03-27-2011, 10:58 AM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,144 Likes on 1,039 Posts
Only two ways to go: Lower the truck or raise the trailer (flip ). Oh, there IS one more...... replace the pin on the trailer with a higher/longer one.
Old 03-27-2011, 07:30 PM
senix's Avatar
senix
senix is offline
Received 1,481 Likes on 1,057 Posts
some pin boxes adjust a little, but I would be very careful on that one.
Also what about going to a larger rim/tire for the 5er? That may help a little but not 4"
Old 03-29-2011, 06:42 AM
seanjackmc's Avatar
seanjackmc
Thanks for all the replies. Drove out to the storage lot yesterday to take a look. The axles on the Montana are already flipped. At least if I understand correctly they are, the axle sits under the leaf springs. There is a 1 inch block that sits on top of the axle between axle and springs. I wonder if someone could machine a 4inch block and buy some longer u bolts. I really dont want to lower the truck I like the way it sits and looks. Ofcourse I forgot my tape measure I wanted to check out how far the actual *** of my trailer was from the ground when level.
Thanks for the ideas. Im thinking I may just leave it alone for camping season and see what happens.
STM
meborder
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
15
07-12-2016 11:11 AM
v101998
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
11-06-2015 06:31 AM
petrokiller
17
09-03-2015 04:59 AM
Joe28443
Toy Hauler Towing; Fifth Wheel & Bumper Pull
19
07-06-2015 11:46 AM
rangerbait
06-15-2015 08:50 PM
Quick Reply: ok need some help again
