ok need some help again
So I recently traded in both truck and 5er. New truck is a 2011 F350 CC FX4 SRW. New trailer is a Montana 3750FL. Truck pulls this trailer great. Under all my weights by a good amount. Did a cat scale check to be sure. Only problem is my truck is so high that my trialer looks as if its driving up hill. I actually dragged the butt end pulling out of the truck stop with cat scale. There seems to be some debate on how to raise the trailer. Any ideas. I think 4 inches would make a huge difference. Other then bottoming out I want the weight to be evenly distributed over the trailers tires.
Thanks for the help in advance.
STM
STM
i know what you mean, I lowered the hitch position a couple years ago to level the king pin side, but last year found that I was getting to close to the bed when backing into a couple campsites. I had to slide the hitch back to keep it from hitting. I raised it back up this year in prep for the new camper...we will see how that sits.
Thanks for all the replies. Drove out to the storage lot yesterday to take a look. The axles on the Montana are already flipped. At least if I understand correctly they are, the axle sits under the leaf springs. There is a 1 inch block that sits on top of the axle between axle and springs. I wonder if someone could machine a 4inch block and buy some longer u bolts. I really dont want to lower the truck I like the way it sits and looks. Ofcourse I forgot my tape measure I wanted to check out how far the actual *** of my trailer was from the ground when level.
Thanks for the ideas. Im thinking I may just leave it alone for camping season and see what happens.
STM
STM
meborder
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
15
07-12-2016 11:11 AM
v101998
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
11-06-2015 06:31 AM
petrokiller
17
09-03-2015 04:59 AM
Joe28443
Toy Hauler Towing; Fifth Wheel & Bumper Pull
19
07-06-2015 11:46 AM
rangerbait
06-15-2015 08:50 PM
