Clutch linkage
Old 07-04-2018, 10:19 AM
Mattrobertson's Avatar
Mattrobertson
Mattrobertson is offline
Clutch linkage
Hey guys I have a 78 f150 4x4 with a 302 does anyone know where I can get the bracket that goes on the bell housing for the clutch linkage i think its called the zbar pivot bracket or if anyone has one
Old 07-04-2018, 01:08 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Mattrobertson
Hey guys I have a 78 F150 4x4 with a 302.
Does anyone know where I can get the equalizer (Z) bar bracket that goes on the bell housing for the clutch linkage?
Are you sure it's a 302?
302 (6 valve cover bolts per side) not available with 4WD until 1980.
1977/79 F150/250 4WD's came with either a 300 I-6 or 351M or 400 V8 (8 valve cover bolts per side).
D7TZ-7A572-B .. Equalizer Bar Pivot - Inner (engine side) / Obsolete
1977 F100/150 302 from serial number Y80,001 / 1978/79 F100/150 302.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
Old 07-04-2018, 01:14 PM
Mattrobertson
It had a 351 but I swapped it for a 302 fuel injected motor out of a 93
Old 07-12-2018, 04:21 PM
dogdays's Avatar
dogdays
dogdays is offline
Driving down the street my clutch pushrod fell out, leaving me with no clutch. Luckily I found the pushrod (7521 in the diagram) but when I try to install it the pedal just goes to the floor. I think it has something to do with the coil spring 7534. Is that what the spring with rollers is for? What's its name?
I'm going to have to take a closer look under the dash when I get home tonight. I probably won't need one, but is it available?
Thanks,
R.
Old 07-12-2018, 07:42 PM
NumberDummy
7534 is the clutch pedal lever assist spring, but there's more than one. What year is your truck, what engine?
Old 07-13-2018, 02:11 PM
dogdays's Avatar
dogdays
dogdays is offline
1977 F150 2wd 351M 4-speed
Thanks,
R.
Old 07-13-2018, 08:20 PM
NumberDummy
D7TZ-7534-B .. Clutch Pedal Lever Assist Spring - 7 1/2 coils, 3 3/8" long / Obsolete
1977/79 F100/350 300/302 (F100/150)/351M; 1978/79 Bronco 351M; Misc 1981/83 F100/350 except 400 V8.
No Ford dealer or obsolete parts vendor has any.
Old 07-17-2018, 04:54 PM
dogdays's Avatar
dogdays
dogdays is offline
I decided to gamble on a 1970 Mustang pedal assist spring looks almost exactly like the one that came in my truck. Length is 3 1/2" so I'm thinking it'll work. Less than $30 from Kentucky Mustang.
What's ironic about this whole thing is that my truck was sold to me as a 400 engine truck but it is really a 351M with a 400 crank and pistons in it. That means I got the clutch linkage for a 351M, if the truck had been a real 400 truck I could have bought real replacement NOS part!
Anyhow, thanks for the help!
R,
uuncledon
02-05-2018 10:21 AM
79-351w-stepside
12-29-2016 10:51 AM
Bearhead
07-01-2015 09:37 AM
Lumpy78
06-24-2009 11:15 AM
brickyiowa
02-03-2006 01:18 AM
Quick Reply: Clutch linkage
