Drag Link
Drag Link
Hey guys, I also posted this in the 'Wanted' area of the classifieds section, but I'm looking for the drag link that runs from the steering box to the front diff on a Hi Boy. I'm looking for a drag link from a hi boy that DID NOT have powersteering (drag link without the ps valves). I'm actually looking for 2 of these drag links. Let me know if you have anything laying around.
Thanks,
Thanks,
I cant help you with the search but an FYI: the drag links with the control valve assembly(CVA) work just the same. You can use either for a manual setup. I understand in wanting to have the manual link. Especially since you can get a decent price or core charge for the CVA links. Just a heads up if you cant find one quickly.
I wouldn't buy a used one, most likely going to be worn anyway, and this is your steering linkage we're talking about here, the parts houses want roughly $140, found this one on ebay for $100, i've seen them as low as $60 on ebay, if you got the time to wait for a better price.
Drag Link 67-77 F-250 Truck - eBay (item 300534661088 end time Apr-07-11 16:15:35 PDT)
I never knew that they worked the same?? Everytime I drove a vehicle with powersteering, but had the powersteering unhooked, it always seemed like the steering was alot sloppier than a vehicle with regular manual steering. I assumed it was because that steering valve did not have pressure running through it.
Any idea what core charge is on this part??
RC raises a very good point, when the system isn't under pressure you will have about an 1/8" to 1/4" of play where the ball stud enters the control valve.
Snuggyworm
1999 to 2016 Super Duty
05-03-2012 08:32 AM
F250GH
02-20-2011 07:59 AM
Faithful Old Road Dog
15
06-26-2004 01:33 AM
