Boost leak detector - PICS!
Aw shucks Pop, that's probably WVO also.
I made a boost leak detector, and installed it where the air cleaner/air box fitting would connect. Upon applying pressure, I could feel air coming out of the dipstick tube (when I pulled the dipstick). I used low pressures and could find no leaks. Is it really safe to crank it way up as massively pressurize your crankcase? It would seem like you'd immediately either blow out the dipstick or force oil past the main seals or through somewhere else. Did I connect the leak detector in the right location?
I regulated the pressure to 20psi, but the volume of air was low, so I really doubt my engine saw anywhere near that much pressure. Presumably, if you had a boost gauge, you could see the actual pressure in the intercooler/turbo hoses?
Thanks,
Steve
Thanks,
Steve
Turns out I made the mistake of hooking it up to the CCV coupler just like this. I'll try again later with the detector hooked up to the correct boot.
Next time I hooked to intake tube directly on turbo. CCV hose (no ccv mod) from valve cover was open to daylight. 10 psi from compressor and air came out ccv tube. I plugged with thumb and all went quiet, so no leaks.
is it normal, if the hpop drive gear cover is bent and already leaking, for all pressure during boost leak detection procedure to escape via that spot? the leak is so bad there that i cant even build up any pressure on the gague on my air regulator.
im guessing this explains my incredibly low boost and 10mpg huh?
xtof
xtof
SkySkiJason
16
12-03-2016 09:29 PM
SkySkiJason
20
12-24-2012 08:22 AM
SkySkiJason
32
09-06-2012 12:57 PM
