Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Northern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Northern Chapter Join Chapter , Leader: Nighteyez
  #1 (permalink)
Old 03-10-2011, 07:25 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Garage is empty, add now
Jag Red 54 has a good reputation on FTE.Jag Red 54 has a good reputation on FTE.Jag Red 54 has a good reputation on FTE.
6-Volt LED Tail Light Questions
I am trying to convert from standard 6-volt bulbs in my tail lights to LED. The more the better. I need them to work as tail, blinker and brake lights. Has anybody done this? Is there a supplier that makes these? Also, is there a problem with the flasher not working because the current draw is so low? Thanks, Jag
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
  #2 (permalink)
Old 03-11-2011, 02:29 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
This is a common conversion and there are all sorts of bulbs available so I would suspect that someone offers 6V LED bulbs as well as 12V.
You just have to put the bulbs in and try it to see if your flasher will still work. If not, there are special flashers available to coreect the problem. I think there's a resistor or something you can get as well to create enough resistanse to get the flasher to heat up enough to work correctly...something like that, don't recall offhand.
Google is your friend, here are a couple that came up:
Super Bright LEDs - Boat, RV and Other LED Bulbs
6 Volt LED Positive or Negative Ground Auto Replacement Bulbs
Light Bulbs Classic Auto Bulbs Automotive Replacement Light Bulbs
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 03-13-2011, 11:45 PM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
Elder Blossom Wine
aawlberninf350 has a very good reputation on FTE.aawlberninf350 has a very good reputation on FTE.aawlberninf350 has a very good reputation on FTE.
I tried LEDs on my 75, and they sucked; nice quick response but just not as bright as regular 1157s. But this was before the current crop of uber-bright LEDs came out, so perhaps they are better now.
__________________
David
2002 F350 7.3 CCSB 4X4 sleeved AIS WW Mishimoto 6.0 IC 6.0 trans cooler 26 row RiffRaff: FRx Plenum Reinforcers AIH Delete Boots
Isspro EVs 50 cent mod Foil delete Hutch Harpoon DP Tuner Walker BTM 4R100 w/FTVB nlemerise AC mod Mile Marker 449ss RedHead 08 diff cover Fumoto DDM HID 55w 4500k Bilsteins DieselSite Coolant Filter Donaldson ELF7405
  #4 (permalink)
Old 03-14-2011, 10:59 AM
Jag Red 54's Avatar
Thanks for the feedback guys, I need the help. I am looking to get a large disk of lights (4" +/-) to give the biggest light possible. I tried out the idea of using 12" LED from HF, but they won't light up at all. :-( One possible cheap application may be from lantern flashlights! Jag
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
  #5 (permalink)
Old 03-14-2011, 12:25 PM
jd_sylvia's Avatar
jd_sylvia jd_sylvia is offline
1965 Ford F-100
jd_sylvia is starting off with a positive reputation.
I tried the LEDs about 6 years ago and was not impressed what so ever, but with the newer technology they might be better than standard. I was thinking on giving them another try myself.
__________________
Jon
1965 Ford F-100
352 V8
Tags
1967, 1978, brake, bronco, ford, led, light, lights, make, tail, tailight, taillights, tailstop, truck, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
