Tail Light Help
Old Oct 21, 2016 | 12:23 PM
df85732's Avatar
df85732
Tail Light Help
I'm working on my rear Tail lights today. I replaced all the wiring, bulbs and housings, but can only get the turn signals and brake lights to work, and they work good. I have a 6 volt system and replaced the bulbs with new, 2 filament 6 volt bulbs. All front lights work (Headlights, turn signals and parking lights)
Any ideas why the rear tail lights will not come on?
Probably something simple......I hope! Thanks
Old Oct 21, 2016 | 02:26 PM
51fred's Avatar
51fred
Are your Brake/ Turn signals hooked to one filament and the tail lights to the other?
Old Jun 8, 2018 | 09:41 AM
Weberda328jw's Avatar
Weberda328jw
7th Gear
Around we're they grounded it black at back driver side and we're good green clip rear has black yellow make shur plug it yellow black strip blinkers driver that's what found I popping fuses about time I checked my own
Old Jun 8, 2018 | 01:10 PM
Carbonarc's Avatar
Carbonarc
Assuming the wiring is correct, first check for voltage at the tail light socket with a test light to a known good ground. If you have voltage then it will have to be a bad ground or defective bulb. Good luck!
Old Jun 8, 2018 | 09:22 PM
abe's Avatar
abe
Huh? Say what?
This is an old thread. Thanks for the help. But I'm sure Dave has it figured out by now.
Old Jun 9, 2018 | 03:49 AM
Carbonarc's Avatar
Carbonarc
Thanks, Abe. I missed that this is an old thread.
jreilly57
Nov 11, 2013 08:03 AM
78_f150
Jun 4, 2010 11:36 PM
oldschool84f150
Oct 13, 2009 12:07 AM
1974oneton
Sep 15, 2009 06:44 PM
74f100gg
Apr 14, 2005 12:41 AM
