Coolant temp sensor symptoms
on
Lately ive noticed that my truck warms up fine, gets amazing heat from vents but the gauge doesnt even go past the first mark. it barely lifts past the "c". Im wandering if this is causing my loss of power because the truck still thinks its cold? Could this be the coolant temp sensor?
Symptoms:
-Obviously the gauge reading cold
-Truck gets random loss of power when around 3/4 throttle
-Gas mileage is still fairly normal (around 13mpg)
-Sometimes chuggs and bucks at lower speeds
Symptoms:
on
The engine temp sensor and the dash gauge sensor are two seperate items, the one on the thermostat housing is for the engine and if it is out of range you will get a code for it. The dash sensor is a little single wire thing in front of the #5 injector in the lower intake, normal operation for this gauge tends to be on the low end of the scale though mine reads more towards the middle since I replaced the original sensor with a new aftermarket one.
That said I doubt your problems are related to these sensors, I suggest you pull the codes to see what is being flagged.
Symptoms:
Symptoms:
Symptoms:
Symptoms:
hello I was wondering if you fixed your issue? I'e been having similar problems .
Help me please
I have an 88 f150 inline6. This is the type of truck you have right? If so could you contact me. I' new to this site and not sure if a reply on here will go to my email. But here is my email if you decide to chat. Jbrueckner1228@gmail.com. I am not a bot or anythi g like that. Hope to hear from ya
kg6mov
29
09-02-2016 06:40 PM
Makeroftoys
1983 - 2012 Ranger & B-Series
06-29-2016 03:41 PM
