Modular V10 (6.8l)
00 v10 coil pack bolt broken
Old 03-01-2011, 10:47 PM
trucktech's Avatar
trucktech
trucktech is offline
I just got my 00 excursion and was gonna change plugs. It has 104k miles on it and I took 1-7 coils out and when I went to loose #8 and bolt broke flush. Any good ideas for this solution?
Old 03-02-2011, 01:01 AM
Zedrive's Avatar
Zedrive
Zedrive is offline
I would get left hand fluted drills, the ones which cut counter clockwise, and drill it out.. The bolt may back out while your drilling it hence, the left hand drills. An easy out might work but, I would not want one breaking off in such a small hole. Great trouble then.
I have drilled out afew broken bolts although, not on my Ford. Use a center punch and get it right in the middle, centering the drill bit is crucial. Penetrating oil would be a good idea to use.
Thats how I'd roll.
Old 03-02-2011, 05:32 AM
JWA's Avatar
JWA
JWA is online now
Received 1,394 Likes on 1,103 Posts
Zedrive seems to speak from experience so certainly use his advice about this---sounds reasonable to me. Maybe also use a tap to clean the threads after removal, get a new bolt directly from Ford---about $5 each though.
Use a dab of anti-seize when re-installing too----can't hurt a bit and will prevent this from happening next time.
Old 03-02-2011, 05:57 AM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
Easy as pie.
Old 03-02-2011, 11:32 AM
trucktech's Avatar
trucktech
Is the bolt a ground for the coil pack or is it just for hold down?
Old 03-02-2011, 12:29 PM
Zedrive's Avatar
Zedrive
Zedrive is offline
I believe it is just a hold down. Also they only torque to 3-4 ft lbs.
BigPigDaddy posted up a better method if you got a welder handy. Either way patience will pay off.
Old 03-02-2011, 03:53 PM
dkf's Avatar
dkf
dkf is offline
Pick up the correct size easy out and the specified size left hand drill for the easy out. Center punch the broken bolt in the center and drill down far enough so the easy out can get a grip. The bolt will probably work its way out during the drilling process as Zedrive said. I remove broken bolts all the time with that method.
Old 03-03-2011, 11:51 PM
trucktech's Avatar
trucktech
I drilled it and used a extractor and it broke off inside the drilled out part. So off to the shop it goes (lack of a welder to tack a nut on)
Old 03-04-2011, 01:30 AM
p-nut's Avatar
p-nut
p-nut is offline
f- that, run it without the bolt. Use a little di-electric grease around the outside of the plug boot to assist holding it in.
Old 03-04-2011, 04:32 AM
JWA's Avatar
JWA
JWA is online now
Yeah---WTH you've got 9 other cylinders firing----no need to worry 'bout just one coming loose, losing contact and misfires! Screw it-----don't matter anyway!
Old 03-04-2011, 12:01 PM
trucktech's Avatar
trucktech
it misfires really good with out that bolt in.
Old 03-05-2011, 05:24 AM
BigPigDaddy
There is just something about mechanical advice that starts with "f- that" that makes me think twice. It's even more questionable when your avatar is an Audi emblem.
Just kidding with you p-nut!
Old 03-05-2011, 07:08 AM
F-7's Avatar
F-7
F-7 is offline
it is a ground I had the same thing happen to the tee. I made a small bracket and bolted it to the valve cover stud works great. I can post a pic if you like
Old 03-05-2011, 07:38 AM
JWA's Avatar
JWA
JWA is online now
Abosolutely just kidding-----but it does make me ask how many of those "professional mechanics" at the stealerships and lube 'n rob quicky oil change places utter that same thing from time to time?
Then again change the rear shocks on an E van and F-That comes to mind repeatedly!
Mprov1999
07-19-2017 07:42 AM
thegreatgate
1997 - 2003 F150
03-21-2016 04:57 PM
Notmeofficer
09-14-2012 12:13 PM
the truth
1999 to 2016 Super Duty
13
02-18-2012 07:21 AM
Quick Reply: 00 v10 coil pack bolt broken
