7.5 in a foxbody
7.5 in a foxbody
I have a 79 Mercury Capri that I am wanting to do a engine swap with. I can get a 460 from a friend to put in my car and what I originally was thinking i could simply switch out the front suspension with 5.0 parts to make up the difference. I talked over the idea with my grandfather and he said that the car wouldn't hold the weight with out plenty of fab work such as major suspension upgrade and some sort of frame to attach to the rear of the car to make it solid. I understand that I could simply put in a 302 or 351 easier and have abundant power if I built it right but I really want to use the 460 because it would be quite a bit more impressive to do. Does anyone have any know how about doing something like this?
I realize I would be dropping almost half a ton into the front end, but there are coil over conversions that could take the weight if I can find the right one. The torque could be tamed by other means, i'm looking into sub frame connectors but not sure if that would be enough. I was hoping someone would have some experience with doing something like this. If so your help would be very much appreciated.
http://bigblockfox.com/
just like droppin any other v8 in. Just way bigger there are after market swap mounts for the motor, and you can get a 460 bell for a c4 tranny and there you go its all tucked in there.
Tsaven Nava
02-25-2006 11:41 AM
