Rear window switch?
There are actually TWO switches in the tailgate. One engages when you turn the key one way, the other engages the other direction. You may have a switch gone bad or just loose connections or the switch itself may have dislodged from its mount. Best bet is to open the gate, manually close the driver's side latch (both cams), then run the window up. Take care to support the glass as it reaches the full up position. From this point you can remove the inspection cover on the inside of the gate and get at the switches which are mounted behind the key tumbler assembly. There is a paddle on the tumbler assembly that rotates to activate the individual switches.
Berardini2121
1978 - 1996 Big Bronco
09-15-2018 07:53 PM
kyledallas
19
01-03-2012 04:42 PM
krantzfamily
10-31-2004 08:12 PM
