Radio Antennas for 48-50. Lets see what you used and where
Hey guys,
Who all has put an antenna in their 48-50. I know there are options of original cowl location, frenching it in the former gas tank filler hole or grounding it to the body. Let's see what you all chose for your ride. Thanks in advance.
We've got a local guy that has an F1 with his antenna frenched in at the same location as the one I put in my F100. I don't know if it's funtional because it's usually only sticking up about 4-6". His truck is black with a ton of modifications including a chopped top. I'll check to see if I have a photo of it.
i have used the hidden ones on several harleys up in the batwing fairing. They work ok. i found one on ebay that is a ribbon style, there is sticky on one side and you could put it up high in the dash and it works well (kinda like a piece of tape). Its what i have used before and plan on using on mine to get rid of the one above the F1 emblem when the time comes. I personally don't care for the powered hidden antennas. Allot more $ and don't work a bit getter and usually worse.
Moe Craig
03-10-2015 09:38 PM
49 ford fire truck
01-09-2015 05:59 PM
aldrowsboy
11-10-2013 10:12 PM
