thump thump??
thump thump??
well thanks to the AWESOME new england roads its taking a beating on my truck... backed out of the driveway the other day and i heard thump then pulled forward and it thumped again like somehting was going back into place... jacked up the front end to see if i messed up the ball joints or something from the job a few weeks back. everything is super tight in the front end. core support and cab mounts are all mint? would a leaf spring shackle make that kind of noise? its more of a torquing the body kind of deal or when im turning and hit a good bump that gets it to thump. i may hear it 2 or 3 times a day.
let me know on ideas to check for. oh and its only the passenger side front thats doing it. all new ball joints and tie rods are tight and new u joints, zero slop from what i see
ive got to check the bushings in the front end shes 4 wheel so i have this awesome scissor turd. truck sits level so probably not the hanger then. the leafs are ok, no breaks from what i can see. engine mounts are mint, engine never shakes the truck, havent noticed anything out of the ordinary.
i can try the fender bolts but, when i first got my truck the fender was loose and dont quit think the sounds are the same...last night it did it annoyingly alot. i also had alot of turning in tight spots with bumps though.
same set up as yours, doesnt sound like its a brake issue, its mainly when im backing up and turning all the way because it sounds like something is getting flexed and pushed out of place, then when i pull back forward it flexes back into place and thumps again. its really annoying. drives straight as a whistle and doesnt give me a single issue going down the road.
EBrake light/Antilock lights illuminated...all the time.
Have a soft pedal, almost to floor...she'll stop ok...
Need direction to a laundry list of "what to check" and eliminate from there...
Brake fluid level ok. No leaks noted.
AE won't help me on this one!
....What the....did I do!...meant this for a new thread!...time to go to bed..
Rays auto
1999 to 2016 Super Duty
09-06-2016 10:49 PM
christyj
1997-2006 Expedition & Navigator
20
12-15-2014 11:33 AM
TNT
01-09-2011 11:56 AM
