Replacing Universal Joints
Old 02-16-2011, 08:19 AM
Justin's Green Truck's Avatar
Justin's Green Truck is offline
Hi, we have two 99 F150's where I work and they both need new u-joints. One is 4X4 and the other is two wheel drive. Both are automatic trans, 4.6L
I know how to remove the driveshaft from the vehicle, but have never changed u-joints. Is there any special tool or technique required to drive them out? Thanks.
Old 02-16-2011, 11:04 AM
moto57's Avatar
moto57
moto57 is offline
Rent(free) a U Joint press from a local Auto parts store, lock the press in a bench vise. or Old School using a BFH and Sockets.
Don't forget before you remove the drive shafts to use a marker to mark the relation of the shaft and the slip yoke(they are balanced) Oh yea, a little PB helps too.
Old 02-16-2011, 12:31 PM
N832's Avatar
N832
N832 is offline
I like to take out the drive shaft then take it to a driveline shop. They will replace the joints and balance for a very small fee. saves the headache and then they are balanced. The picture shown is a ball joint press. It should work if you set it up right..
Old 02-16-2011, 03:43 PM
moto57's Avatar
moto57
moto57 is offline
It's listed as a Ball Joint/U Joint/C frame Press, It does works great!
I was refering to marking the Drive Shaft/Differential Pinion Flange before you remove the bolts holding both together so they get reinstalled in the same exact position that you removed them. These marks ensure that the drive shafts dynamic balance will be restored when the driveshaft is installed again.
Tailgate55
01-16-2014 07:02 PM
temptee
06-22-2008 02:09 PM
tietje_3
1999 to 2016 Super Duty
10-13-2006 08:32 PM
rondog
09-06-2001 12:21 PM
Quick Reply: Replacing Universal Joints
