Which u-joint press
Old Jun 20, 2008 | 07:06 AM
temptee's Avatar
temptee
Which u-joint press
I just bought the u-joint press from harbor freight (the $34.99). Their flier advertizement that came in the box shows a press for "4-wheel drive" for (45.99 or so). I have a 4x4. What's the difference between the two? I plan on doing ball joints also.
Old Jun 20, 2008 | 08:30 AM
jas88's Avatar
jas88
If I am looking at the right item, I consider that tool for pressing ball joints into an a-arm, not for u-joints. I have one of those big 20 ton presses from HF now, but I pressed a many a ball joint before that using a vise and a socket.
Old Jun 20, 2008 | 09:57 AM
rainbowATF's Avatar
rainbowATF
They differ in the number and kind of adapters supplied. I bought the 4x4 kit as well; lasted for one ball joint on my 95 F150. C-clamp cracked in half on second balljoint. Metal looked crystalline inside. I then bought their master adapter kit and a 20 ton press. I also use a Big forged C-clamp that was my grandfathers; as well as his vise and some sockets for u-joints.
Old Jun 20, 2008 | 12:14 PM
temptee's Avatar
temptee
I bought the 3 in 1 kit to do the 4x4 front axle u-joints. It is also for ball joints. Apparently u-joints can be done with simpler tools. I found this link which is awsome to explain this job - - only tools required are a screwdriver, hammer and pliers.
Pirate4x4.Com - Installing a Ujoint
I was going to do the ball joints too on my '95 F150 because the right side was done years ago (at a dealer for $800), and I figure they should be done. I'm not so sure as I'm hearing about the broken C-frame (probably aluminum if the metal is crystaline, and mine feels "light" relative to the size of the thing). It would be a shame to have gotten to this point and not try to do them.
If anybody has a similar link to a step-by-step ball joint for a F150 upper and lower ball joint replacement as good as above link, please post it.
Also,
The ribs on the shaft have a deep score on it. I will add the picture if I can figure out how to post it. Do I need to replace it? How much is the short axle new?
Thanks
Old Jun 20, 2008 | 01:08 PM
quicklook2's Avatar
quicklook2
vise and socket is all i have ever used.
Old Jun 20, 2008 | 06:31 PM
trgrhappy's Avatar
trgrhappy
I used the harbor Freight 3 in 1 to do the ball joints on my 89 F150. They were the original ball joints so they were in there pretty tight. Ended up using my impact wrench on the press to get them off. It wasn't that hard of a job once I got the joints off.
As for u-joints, I use a c-clamp and sockets. Works every time.
Old Jun 20, 2008 | 08:57 PM
McLeod's Avatar
McLeod
I bought the 4065-4vga 4WD kit from harbor frieght.
It did the ball joints, the steering u joints as well as assist in replacing the axle pivot bushings.
The key to NOT breaking the c clamp is to tighten the clamp up, put a fair, but not excessive amount of pressure on it and them lightly but firmly tap either or both ends of the c clamp (or threaded shaft as the case may be) with a hammer a few times. Then tighten some more, then repeat. Don't try to press it out all in one shot.
Old Jun 22, 2008 | 12:02 AM
deeznuts822's Avatar
deeznuts822
thats the key tighten alil then tap. I did ball joints on my truck with just the adaptors that came with the press. It also worked good on pushing out rear spring bolts in the leaf springs
Old Jun 22, 2008 | 09:40 AM
LilDuke's Avatar
LilDuke
Thats also all I've done. It helps that I also have a complete 3/4" socket set too. Makes for the "big" jobs easier.
Old Jun 22, 2008 | 02:09 PM
McLeod's Avatar
McLeod
I've done the same also.
I like the benefit of using the press because you can typically take the tool to the work, where as if you use a vise you must take the work to the tool.
With the vise method, the work most likely must be supported.
With the press, the work can lay on the bench.
Just a matter of convenience and sometimes ease.
genscripter
Jan 29, 2013 11:42 PM
Jayme Duty
Jan 28, 2011 12:48 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Jan 31, 2008 09:57 PM
trotskyR
Nov 23, 2007 08:12 PM
79pos
1997 - 2003 F150
Jul 8, 2007 11:10 PM
