Crank.. No start.. P1663 FDCS Circuit Failure
I know there is tons of good info here, and I am in the process of searching as we go, but I am in a bit of a time crunch!
The ol project truck got wired up and new batteries for fire up today! This is my 94/97 hybrid, LOL! For all purposes, its a 97 F250HD 7.3 Auto 4x4 for trouble shooting..
I got everything hooked up, checked wiring and went to start it with no luck. Here is what has happened:
Any ideas? I got get this truck up and going asap, or its going into storage for a long time, as I am moving at the end of this week, and will have to leave it behind to be picked up another year. Thank you!!
- Engine cranks, wont fire up. Engine RPM is good as brand new 850cca batteries were just installed.
- Lights are good and operational
- "NO" mileage readout on the gauges! Blank screen where mileage should be.
- Check engine light comes on very briefly, then off imediately.
- "WTS" light comes on for about 5 seconds, then off. You can hear relay really fire up!
- As cranking, "Fuel Filter" light and "Water in fuel" light come on.
- "RPM" gauge comes up by about 200rpm but doesnt bounce as engine cranks.
- GPR gets pretty hot to the touch and even smoked
- First Code: P0603
- Second Code: P0334
- P1663
I would take the chip out first of all just to eliminate that. Fdcs is fuel delivery command signal. with some limited searching I came up with a possible faulty pcm or idm. Canyou swap in a different one to try? Here's a little of what I found
Fuel Delivery Command Signal (FDCS)
T1 DIAGNOSTIC TROUBLE CODE (DTC) P1663 — FDCS CIRCUIT FAILURE
DTC 1663 indicated that the PCM has detected a failure on the FDCS line.
Possible causes:
Open/short in FDCS circuit
Non-powered IDM
IDM
PCM
Check for other codes.
Key on, engine off.
Perform KOEO On-Demand Self Test and retrieve Continuous DTCs
If you pull the chip , make sure the key is in your pocket...
Possible causes:
Non-powered IDM
IDM
PCM
Key on, engine off.
Craig: Brand new filters and lubes! New O-rings, gaskets, belts and hoses!
Rick and Justin: Not sure I can pull the chip and all will work. I dont have the key, as I am not the one that originally put this chip in. If I pull the chip, will I kill the memory?
Glenn: I will check on that WAG wiring! Isnt there supposed to be a wire that runs to the fuel bowl that has an inline fuse? If so, where does that wire originate from?
on
As for an update.. What a nightmare!!! I went to a variety of autoparts shops looking to get a new computer, after seeing brand new they are around $130. Problem being, order and shipping time. Many of them will get it to me next week.. Not working on my schedule. I had serious issues with the rocket scientists at Autozone.. They wouldnt get me any info unless I provided a VIN. Problem being.. the engine and computer are from the donor truck, which has been recylced into a park bench or something, along with all the paperwork!
So I went to the dealership here. I originally hit the first parts guy up for the computer.. $580.. I think not! I told I needed a moment to think over that price.. he walked away from the counter leaving me to wonder.. I asked to speak to the head service tech supervisor here. The service manager was really patient and helpful with me. She went over the codes and process I went through to trouble shoot the problem. The final code (P1663) I told her about. She went online through the Ford Service Tech manuals and info, found that its the IDM that has failed. Good news.. TJ's advice with the chip out can be tested with some promise, and I will need to get a new IDM. I am not going through the dealership on that one.. $1140 is what they want for one, and it takes 2 weeks to ship. I have another source down here I am going to tap and see where it goes from there.. I will keep ya'll updated! Thank you all for the help!!!
More info..
Thought I would share the video of its first start too..
[IMG]******** width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Q2l4Te9qs6M?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Q2l4Te9qs6M?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed>*********>[/IMG]
basstardo
02-11-2017 05:23 PM
Volkskid
10-13-2014 09:25 PM
mq1shooter
243
10-14-2010 09:36 AM
