03 6.0 - Died while running, no start.
I've been doing a lot of research here and am trying to diagnose what's going on with my step-dad's truck. It's a 2003 F350 with the infamous 6.0. He's had it in the shop countless times, thrown a ton of money at it, and every time he gets it back, either something else seems to be wrong with it or it does the next day. It's causing nothing but problems and putting a hole in the wallet.
So recently he was having trouble getting it started. He asked if I'd take a quick look at it. He replaced both fuel filters and I replaced a fuse that looked a little corroded (I think it was for the fuel pump if my memory serves me right). After that, it fired up no problem. He ran some errands a few days later and left the truck running when he ran into a grocery store. When he came out, it had died and wouldn't start back up. He had it towed back to their house and this is where I came in.
I tried to start it first off and found the batteries were quite low. Strange, I thought, considering he had just had them plugged in for 8 hours a day or two earlier. I load tested both batteries and they looked good.
I think I'm getting ahead of myself though. Let me list what I've done relating to The Big List.
1. Pull diagnostic trouble codes (DTC's) if you can (you can have codes without a Check Engine Light).
I pulled the codes and found a handful of issues
P006A - MAP Sensor Issue
P0263 - Cylinder 1 Fuel Injector Fault
P0266 - Cylinder 2 Fuel Injector Fault
P0401 - EGR Issue
P0674 - Cylinder 4 Glow Plug Circuit Fault
P0678 - Cylinder 8 Glow Plug Circuit Fault
P132B - Turbo Issue where PCM Cycles Turbo between 15% - 85% to break it loose?
I don't know how long these codes have been stored. I know he had a couple fuel injectors replaced previously as well as the turbo rebuilt/replaced. I have no other information on what was done though.
2. Automatic transmission shift lever fully in PARK or NEUTRAL? Try restarting while slightly moving the gearshift lever.
Verified this is not the problem.
4. Battery connections (all including grounds) - all good? Alternator cable connections good?
I unhooked the connections when I load tested the battery. Seemed fine.
7. Is the starter engaging? Verify starter and ignition switch are working properly.
Seems to be fine.
8. Load test BOTH batteries individually and check the charging system (alternator). PCM needs to see 100 rpm minimum to start IIRC.
Appeared good.
10. Could a factory or aftermarket anti-theft device be causing the problem (Passive Active Theft System - PATS)? Disconnect it if possible. Same w/ a remote start system.
No aftermarket anti-theft.
11. Push the reset on the emergency fuel cut-off switch.
I couldn't find this. Any idea where it's located? I read that it's in the passenger foot well but where?
14. Verify that the oil level is correct and the proper oil and filter have been installed. Oil foaming and loss of viscosity (too thick or fuel diluted) can be an issue. Check oil level for fuel dilution, inspect oil condition, maybe even change oil and filter. Definitely make sure you filled w/ the proper oil.
Oil and filter were changed the other day but this was done after I started diagnosing things. I haven't been there since.
17. Change both fuel filters, inspect appearance of the fuel when draining the water separator (you could just have bad fuel).
Make sure that the air is purged on start-up. By following the proper (KOEO) cycling procedure before cranking."
Done.
19. If you have no fuel flow or low pressure, it could be a bad pump (HFCM), OR it could be a plugged fuel filter or plugged lines. You can blow air through the lines to check for plugging. If there is no pluggage, test the pump. First, pull fuse 302 (PCM) and relay 304 (FICM) and then pull the secondary (upper) fuel filter, remove any fuel, and then verify that it is being filled by cranking the engine. As it is being filled, make sure there are no air bubbles. If there are, you have a leak in some connections, the HFCM suction line, or the HFCM o-ring (most likely). Be sure to lube the o-ring w/ oil before re-installing....
I was by myself but I did take the lid off the secondary filter and turned the key to run. It filled the bowl quickly.
20. Pull the oil filter top and have someone crank it while you watch to see if any oil is flowing into the filter housing. If not then it is a LPO problem. Take a long extension and hold down the check valve (round black thing held up by a spring). Have someone crank the engine. The housing should fill within about 10 seconds of cranking.
I didn't have a helper.
I only included the tests that I've done so far in order to save space. One thing I did notice was that if I cranked it for a few seconds and ran to the back of the truck to smell the exhaust, I could not smell any fuel - whether burnt or fresh.
Where should I go from here. Clearly, the codes need attention but I don't know if they are new or old. If I clear them, the truck still won't start so I won't be able to see what comes back. Help!
Thanks in advance as well.
Chris
Last edited by 4.9inline6; Sep 20, 2012 at 11:07 AM. Reason: Typo on the year. 2003 F350 6.0 is correct.
FICM Main Power, Logic Power, and Vehicle Power
Injector Control Pressure
Fuel Pump Duty Cycle
VGT Duty Cycle
IAT2
Cylinder Misfire Counts
Injector Timings
...and a lot more that seem more fun/handy than anything.
Is this good enough or should I look into the Scan Gauge II?
Sorry it was a typo in the text, not the title. It's an '03 F350 6.0. I fixed it in my text. Thanks for catching that.
I saw the FICM diagnosis. I take it that's the next logical test. Follow up question (and something I probably should have mentioned earlier): Though that batteries passed the load test and have been charged, when cranking the key, they seem to be lacking 'juice'. The starter rolls the engine over quite slow. If the batteries aren't charging properly, that will affect the FICM diagnosis, correct?
The FICM test instructions say 03-04 have 7 screws under the panel. 04 and up have 4. This truck is an 03 so it should have 7 screws, right? It had 4... I went ahead and tested it any way. The key on test was good. 48 volts. The other two tests failed completely. Testing during the buzz test and while cranking gave me 0 volts.
So, it sounds like it's the FICM that's bad. But... Do I have the wrong FICM to begin with?
Thanks in advance!
