ran a predator back in the day. good off road carb. One of the things to check is throttle plate clearance inside. make sure not rubbin. Also make sure you gskt on btm is in good shape/not uneven. If you torque unevely could bind up throttle rod or distort housing. Reason I quit running my predator was because of the stripped out threads. salt water is hell on parts. bolts stripped out and the housing started moving around and just never stayed straight/square and plate would bind up.
