Fire!! 460 1987 E350
Old Feb 15, 2011 | 10:30 PM
scottaklassen's Avatar
scottaklassen
I had a small fire that melted vacuum lines. Rebuilt 4180C, had little leak from bowl and accel pump. Replaced most lines but runs rough until warm and in an instant runs great. Better than ever. I have a couple questions like, where do I connect a line to the tube thats going to the choke? I think its to heat the choke faster but am unsure. Also there is a white line that ran off the vcv and it says it goes to a E in the carb circle in the vac diagram. The small port under the bowl has a rubber cap on it. can I provide vacuum to the vcv from that small port next to the large port? Also a yellow colored line on the diagram runs to a S in the carb circle and goes to a fuel tank valve. What should I do with that? Any help would be great.
http://i1091.photobucket.com/albums/...en1976/775.jpg
Old Feb 16, 2011 | 02:59 PM
beetle's Avatar
beetle
I know the emissions systems on these pretty well but I can never make sense of the diagrams. Is it a california model?
You may get a response if you could post some pics of the areas of concern.
Old Feb 16, 2011 | 06:19 PM
scottaklassen
re did a few lines and now no spark when cranking but as soon as you let go of the key, one spark. ran good yesterday and nothing today.
Old Feb 16, 2011 | 09:16 PM
Sw1tchfoot's Avatar
Sw1tchfoot
The choke port loops to a fresh air port like this:
http://img38.imageshack.us/img38/9821/imgp3227.jpg
Scorcher21
Feb 1, 2016 12:50 PM
jmulvihill
28
Jan 11, 2013 07:44 PM
scottaklassen
Feb 16, 2011 10:24 AM
scottaklassen
Feb 15, 2011 08:06 PM
youngguy
Mar 15, 2004 08:07 PM
