Attempted theft now it wont start.
So I got this friend that has a 2004 ranger. Its a V6 with an auto trans. The other night someone decided they liked his aftermarket radio enough to break into it and steal the radio. While they were in there I guess they figured they liked the truck enough so they hit the steering column with something and broke the bottom plastic piece and the plastic around the key tumbler. The theft like is blinking now and it will not start. The key goes in fine and turns smoothly but it jsut wont start. We tried to wiggle the gear shifter around but no such luck. After reading on here I understand that there is an Anti theft switch in the column that can be triggered with any direct blows to the column? If this is the case how do you reset or correct the issue? Thanks for the help guys.
There is supposed to be an antenna for transceiver to read code in key to allow truck to start. It may be a short length of wire or built in to ring around cylinder. Check to see if transceiver or ring around ignition is broken. Check for blown fuses. When radio was pulled if wires were cut a fuse could have blown which could be a power source for PATS. In particular cig lighter fuse which is mentioned in link.
Everything you wanted to know about PATS. - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Well the thief tried to pry the ignition tumbler out of the column and in the process broke the sensor that goes around it. There are thousands of small copper strands hanging out so I assume that is my problem. Can I purchase that part and make this thing work again or will there need to be some programing performed?
Niknik68955
2004 - 2008 F150
10-19-2015 07:16 PM
trun10tion
1997-2006 Expedition & Navigator
04-07-2015 10:02 PM
757Boss
26
03-04-2014 08:25 PM
