problem with keyless entry
not the remotes. its the actuators. easy to fix. i used 2 pennies
https://www.ford-trucks.com/forums/9...-pictures.html
Do you have weak door locks that 'wiggle' or do they not work at all?
If they wiggle, its the 2 cent fix as described above.
If they don't work at all, or work only sometimes, its may be your GEM module. It's expensive. I've learned to live with my remotes only working 'some of the time'.
Yep, sounds like the GEM. I found the part to be too expensive to warrant replacing to solve the problems of intermittent locks. Plus, I believe you have to have the dealer reprogram the GEM, so even if you found a used one, you would still have to pay the dealer.
I just try the remote once, if it opens I'm in....if not I turn the key. It probably works about 70percent of the time.
The GEM/VSM controls damn near all the acessories on your truck and is progammed for your truck as far as model and eqipment. Unless you can find one off an identical truck it would have to be reprogrammed by a Ford dealership to work in your truck. If you buy a new one it also has to be programmed for your truck.
Don't know if getting your's reprogrammed will fix your problem.
I don't know of any aftermarket remotes that can be installed to actuate the door locks but that doesn't mean they don't exist.
I have seen posts by others who have gone through getting a new or used GEM/VSM and/or the reprogramming. I wish they would chime in.
I always hate to say "Use the search" but I just did.
I used this search string in google search bar and got a bunch of hits VSM or GEM site:ford-trucks.com/forums
Here is a post with similar problem LINK
Here's one on removing the VSm if you should need it LINK
ChunderDownUnder
10-29-2012 06:38 PM
The Sly Wolf
01-07-2004 08:20 PM
